2025 Lamborghini Temerario Full Specs
super8
🚀 |_⚡|M|B💥
Temerario Technical Specifications
Powertrain
  • Engine: V8 Bi-Turbo - Hot-V 4.0l
  • Displacement: 3995,2 cm3 (243,8 cu in)
  • Bore and Stroke: 90 mm x 78,5 mm (3,54 x 3,09 in)
  • Compression Ratio: 1 : 9,3
  • Max power @ rpm (ICE): 800 CV @ 9000-9750 rpm
  • Max power (combined ICE+EE): 920 CV
  • Max torque @ rpm (ICE): 730 Nm @ 4000-7000 rpm
  • Cooling System: Liquid cooled - dedicated circuit for HV components
  • Engine Management System: Central DI - Bosch
  • Lubrication System: Dry sump
Transmission
  • Transmission: Automatic
  • Gearbox: 8 gears
  • Clutch: Dual clutch
Hybrid System
  • Battery: Lithium-ion high specific power battery with pouch cells
  • Generator: P1 eMotor
  • Front e-axle: 220kW @3500rpm
Performance
  • Max Speed: 343 km/h
  • Acceleration 0-100 km/h: 2.7 s
  • Braking 100-0 km/h: 32 m
Body and chassis
  • Frame: Full Aluminium
  • Body: Aluminium
Wheels
  • Tyres – Front: Bridgestone Potenza Sport 255/35 ZR20
  • Tyres – Rear: Bridgestone Potenza Sport 325/30 ZR21
  • Front Rims: 20 x 9J
  • Rear Rims: 21 x 11.5J
Braking system
  • Brakes: CCB Plus (Carbon Ceramic Brakes Plus) brakes with fixed monoblock calipers in aluminum with 10 pistons (front) and 4 pistons (rear)
  • Front Brakes: 410x38mm discs
  • Rear Brakes: 390x32mm discs
  • Wheelbase: 2.658 mm (104,6457 in.)
  • Lenght: 4.706 mm (185,2756 in.)
  • Width (Excluding Mirrors): 1.996 mm (78,58268 in.)
  • Width (Including Mirrors): 2.246 mm (88,4252 in.)
  • Height: 1.201 mm (47,28346 in.)
  • Dry Weight: 1.690 kg (3.725,8 lb)
  • Weight-to-power Ratio: 1,84 kg/CV
