The Lamborghini Temerario turbos runs 36psi of boost?
Stumbled onto this youtube video today and it claims that the motor runs 36psi? Has anyone seen this mentioned elsewhere? That's a TON of boost from the factory. Hard to believe, actually. Any confirmation anywhere?
I've heard the same name from various other videos. That combined with a 10,000 RPM redline is bonkers!
Other than diesel motors, I wonder what other engines run anything near that much boost from the factory.
The only information I could find is this, "The Bugatti Chiron uses a quad-turbocharged W16 engine that runs approximately 38 PSI (2.6 bar) of boost pressure from the factory". Some sources also say the following belong in this group; Bugatti Veyron Super Sport (36.3 PSI), Bugatti Divo (37.7 PSI), Bugatti Centodieci (37.7 PSI). However, you can only achieve these numbers with aftermarket parts and some elbow grease.
